Forged wheels
Rashman said:
Hey Steve :thumb:
Very useful feedback regarding your exhaust. Thanks for that insight :thumb:
When I was looking under our cars at clacketts, I could see that your exhaust is actually lower than mine is at the moment. Yours looked lower than mine by about 30mm.
So yes, I think I will be leaving mine as it is! lol
Regarding bluewater.. yes, you're right, I think we said the 15th June.
I'll definitely be getting the car out this weekend though if the weather is nice :rock:
:thumb:
Does look to be nice this weekend just need someone to set the self levelling lights zero point as found out why my xenons never moved on start up! The front sensor on the anti roll bar was pointing backwards!!
Lol, Blimey.
Should be a quick job to fix.
Perhaps our mutual friend can do that for you.
Rashman said:
Lol, Blimey.
I've asked but its gone quiet the last two days! Must be busy, but don't want to drive it in the dark in case I actually blind someone !!
It stays light until around 8.30-9.00 so hopefully he can see you at some point.
Or perhaps you could lower your car.. that seems to be all the rage at the moment :rolleyes: then you shouldn't blind people.
:D
:D
And then I'll loose my exhaust over the first pot hole! Got Mike at MB Medway to set it tomorrow lunch time :-)
Got my MOT & service done today.. All good and fighting fit :rock:
Only needed a basic service. Got them to do the engine oil & filter and brake fluid.
I also asked them to change my diff oil while they were at it.
It's not part of the service schedule but in my opinion, if it can be changed - change it! :rock:
So I got back and put the BC rims back on :rock:
Mum's birthday today so I took the 63 out to go see her.
Car goes like stink. Properly sling-shots itself down the road!
I think it is loving its new lightweight running shoes! :rock::D
I think he soft Michelins also play their part too :rock:
Didn't hammer it too much as I wanted to re-check/ torque the wheel bolts after having just put the wheels back on.
Got home and re-torqued the bolts and gave the car a wipe down.
Very happy indeed with the new rims.
:thumb:
:thumb:
Glad they have put a smile on your face Rash. What did your Mum think? ;-)
Big grin! :rock:
Mum, although not knowing much about cars, said they look very special. And shiney! Lol
OK Rash you keep rubbing it in with posts on your new shiney wheels! I'm still waiting for mine and I ordered them before you :wallbash:
:D
:D
:eek:
Sorry dude :(
Really sorry to hear you still waiting for your wheels.
I hope you hear some good news soon.
:thumb:
I spent about 20 minutes compiling a lengthy post, only to have the forum decide to log me out.
Can't be bothered to write the whole thing out again, so I am going to summarise:
Around last June, I bought some light weight, 2-piece, forged aluminium BC rims.
Expensive and look awesome.
Must have only been on the car for around 4-5 months before I took them off and stored them before the winter set in.
Stored them in a spare bedroom. Snug, dry, warm and under covers.
As a lot of you know, car is never driven in the rain.
Only driven once every week or two.
Car and wheels are cleaned thoroughly after every drive.
Never use water to clean the car.
Itching to get the wheels back on the car.
Finally got them back on the car about 5-6 weeks ago.
Drove the car. Great to get the car out.
Got home and cleaned the car down.
Discovery made....
2 spider legs on a rear wheel.
Clear coat has failed. :eek::doh:
Must have only done about 200-300 miles on the wheels before storing them last year.
Very disappointed.
Refurb?
Hell, no.
A lot of companies won't even touch split rims.
Contacted Projex and explained the problem.
Have had many conversations with Stewart (owner) and his 2 sons, James & Matt.
They requested pictures.
I sent them pictures.
They requested I send the wheels to them to inspect.
They collected the wheels about 3-4 weeks ago.
Nothing happening yet. Annoyed with this but can't do anything about it.
I am very OCD with my car.
They know this.
I have several concerns.
They are discussing with the factory.
Stewart requested that I voice my concerns in an email so that he has a history of communications he can share with the factory:
Get one wheel re-done?
I don't want this as it is likely the effected wheel won't match the other 3 wheels.
The wheels were made to order.
I am concerned this problem will happen on the other wheels.
James said that he has had to remind BC to take UK climate into account when making wheels and to protect them more.
He said he has had this issue before and that the factory were using different grades/ quantities of clear coat and protection for different regions.
Stewart said that the factory will not consider re-doing all wheels as only 1 wheel is effected.
The wheels were made to order, so they underwent the same manufacturing process.
I am extremely concerned this problem is likely to happen to the other wheels.
Stewart suggested having a new barrel made.
This won't work as one spider leg is on the dish/ barrel and another spider leg is on the face of the wheel.
Factory are unlikely to make a new set of wheels for me.
There was suggestion of a stone chip causing this.
But the effected areas are not forward-rotating sections of the wheel, so I find it hard to accept that a stone (well, 2 stones at the same time) managed to make contact with these areas while in motion.
The effected wheel was the rear right wheel.
Also, there is no impact marks, so I do not believe it was a stone (or 2).
Clear coat has failed in 2 areas.
Spider legs are pretty much the same length, so presumably started creeping at the same time.
Both spider legs start from under the very small gap between the tip of the spoke and the dish.
Even harder to believe that a stone (or 2) made it under that gap without impacting any visible areas of the wheel first.
Still waiting to find out what is happening.
Communication is unfortunately not ideal with Projex.
Although, Stewart has assured me that they are on my side and will get this sorted. So I am being as patient as I can.
Worse case scenario, I get a refund.
Wanted the wheels on the car last year for the PCS meet but there was a mess up with my order, so I didn't have them in time.
Want them on the car for this year's PCS meet, sorry, "Benz On The Green" event.. but it is looking unlikely again.
Not happy.
Can't leave the wheel as it is as it will look like a cheap aftermarket wheel in no time.
Amazed and disappointed that 2 spider legs could appear on such expensive wheels in such a short space of time.
Wheels were waxed inside and out 3 or 4 times before they even went on the car when I first got the wheels.
They have been cleaned and waxed periodically.
Stored in a warm, dry bedroom.
Spider legs appeared during this time.
Both legs about 3/4 of an inch long, about 1/2 an inch apart.
Rash,
Sorry to hear and see that the wheels are not as they should be. You must be really ****** off.
Fingers crossed they get them sorted as soon as.
Hoe all is well wit you other than the above?
Justin
hey Rash, I feel for you mate, esp after all the pain you went through when getting them, hope it all gets sorted.
As you said"Attention to Detail can be a pain"
So sorry to hear . All the pain you went through when you first bought them, now this.
I hope they sort it ASAP. Try and be patient, I know that isn't easy. Hope to see you at Olly's with it sorted.
Thanks for your responses guys.
Appreciate it.
To be honest, I'm getting abit p'd off with it all.
I think this is also a reason why I haven't visited the forum much recently.
But I can't leave that wheel as it is.
I knew this.
I didn't want all this grief and headache but there was no way I was going to leave that wheel in the state it's in.
Fact is, it should never happen.
Not on a wheel that has hardly been on the car.
Never driven in the rain or winter.
Waxed repeatedly.
Stored and kept in a warm, dry bedroom for god's sake!
So, I will be seeing this out.
As I said, I can't accept 1 wheel being re-done.
Sure, the factory may say that it will look exactly like the others, but what if the same problem happens to the other wheels?
By the sound of it, according to Stewart at Projex, they will not be willing to re-do all 4 wheels.
Personally, I think they should agree to do all 4 wheels.
They were made to order and made at the same time.
So it's perfectly reasonable to assume that it's likely the problem may occur with the other wheels.
What if another wheel starts lifting in a year's time?
Where would I stand then?
I don't want to find myself in a situation where I'm told "Sorry, you've had the wheels too long for it to be a manufacturing fault".
Especially considering how little I drive the car.
Still waiting to hear from Projex.
I suspect I will be asking for a refund, which was an option that was suggested to me by Stewart at Projex.
I can't see any other way out of this.
Factory won't make me 4 new wheels.
Factory won't re-do all 4 wheels.
I don't want 1 wheel being done.
There's a chance this could happen to the other 3 wheels.
Refund seems the only viable option.
Wow dude, sorry to hear about this mess. For the amount of money you spent on those wheels, a company like BC should do everything they can to keep their customer happy even if it means getting all 4 wheels done for peace of mind sake.
However, what Ive highlighted above is exactly their strategy by the sounds of it.
I do hope it gets sorted out for you whichever way it pans out.
I think I'd agree regarding a refund. Is it possible to X-ray or something similar to see if the other 3 wheels have problems just beneath the surface?
Hope it works out.
I can just imagine just how cheesed off you are Rash, more so with only 2-300 miles and your car see,s no water, weather driving or cleaning at all:confused: , seems the wheels are not geared to any weather let alone the UK, get your money back and move onto another wheel. That said, not that many for you to choose from given you are so fussy, but I admire that and your passion for your car.:thumb: Best of luck with it all Rash, cars mate, be the death of us all! That said, hopefully see you soon at a meet, seems a few going on in the next few months. This said, broken my foot at mo, can't even drive!LOL:o
Hello Rash - sorry to hear your woes, and I do hope you get a satisfactory result.
