The Pilgrim
Hello gentlemen,
Being in the process to lower my fuel consumption, I found out the description below. Assuming the info is real (I do not have access to any other description or technical info about this engine), it appears obvious that this particular engine fuel management wastes half of the fuel straight in the exhaust system (cat).
In this situation it seems to me that the only way to correct the situation would be to use one injector from each pair and fit them near the butterfly (and take out the other 2 from the system), in order to resemble a monopoint injection style and avoid the waste spray of fuel. Of course the application of this ideea must be thought well.
So, please correct me if I'm wrong and tell me that this engine has a normal sequential injection.
Looking forward for your knowledgeable kind answers.
Yours
Stefan
M111.940
The M111.940 is a 2.0 L (1998 cc) 16-valve engine with bore and stroke of 89.9 x 78.7 mm and compression ratio of 9.6:1. It produces 100kW (136hp) of power and 190 N-m of torque.
Applications:
* 1992-1995 E200
Unlike the 102, 103, and early 104 series engines, the engine did not use mechanical injection but the Siemens PEC/PMS (Pressure Engine Control) management system, which integrates fuel and spark management.
It is a speed-density type of system, as mixture formation is dependent on RPM, TPS angle, and manifold pressure (MAP).
Injectors work in pairs (idle, part load), or altogether (full-load).
It uses 2 ignition coils and no ignition distributor. Cylinders are fired in pairs (dual fire) - 1 and 4 together, and 2 and 3 together. The crankshaft position sensor is sensing the movement of two radially opposed position plates on the flywheel, one of which is magnetized, and the other is not. Thus, the engine management has precise information which group of cylinders to fire, and which group of injectors to spray.
M111.942
Similar to the M111.940 engine, used in the years following. It produces 100kW (134hp, 136PS) of power and 190 N·m (140 lb·ft) of torque.
Applications:
* 1995-2000 E200
Yours
Stefan
M111.940
Applications:
* 1992-1995 E200
M111.942
Applications:
* 1995-2000 E200
