Getting fault codes from ECU warning light
Satch
Surrey
S211 E320Cdi Avantgarde Estate & Toyota Land Cruiser
Have been told that it is possible to get the engine ECU warning light to flash out any fault code sequences (e.g one flash-pause-two flashes = code 12 which is the first "confirm" output of any sequence).
This occurs by shorting out two of the pins (not clear which ones: it seems to vary!) on the diagnostic plug, if you can find it, with paper clip or similar. This is said to be built into a number of Bosch & other systems for those cases where specialist diagnostic kit is not available.
Anybody know if this is correct, if so is it liable to cause damage and where a list of fault codes can be found?? I have no wish nor need to use this facility but can see that one day it just might be damn useful to know.
Is this because you live far from a Benz mechanic ? My dealer never charges to look up the faults.
You're lucky... my local dealer usually wants to charge £35 for a fault code readout of the ECU.
S.
This only applies to cars until ASYYST was born.
Search the net the info is there along with the codes. Sorry no pointers at present but I've seen it.
