Hi All
Recently changed all glow plugs as ohms readings of 3 were way off, so 5 new went in. Retested new ones as well. Plugs harness tested too and with plugs connected readings are 1.1ohms on all.
Read voltage on all 6 socket pins in the GP Relay and all read the battery. Theres another socket with two pins in the relay, both read battery voltage, however on the plug side one of the wire reads a cinsistent 1.7ohms whereas the second wire the ohms are all over the show and never constant.
1. When the car has done a 50+ motorway miles, and when switched off and back on the glow plug light disappears after the usual few seconds and when running, no matter how many times the car is started.
2. Where are the 2 wires leading to that plug in to the 2 pin socket on the GP Relay.
I'm pulling my hair. Why does a long drive resolve the issue? Is the F5 125Amp glow plug fuse playing tricks. If someone can tell me where those two wires lead to I could possible figure out the issue.
Many thanks.
Verve
Many thanks.
Verve
