Grease that Squeaks – CLK W208 Power Seat
Outsources
Hey Guys and Gals! This is my 1st post. I hope I can contribute something in the future in return. So here goes.
I have a 2001 CLK, W208, full function power seats on both sides. The seats when being moved forward are smooth as silk. However, when being moved backwards, it keeps on squeaking after mid way and to the end of their tracks. This is for both with and without someone sitting on them. The driver side is more pronounced.
I apply some heavy grease on the track and roll the seat back and forth to get the grease going. And to my surprise, the squeak turned into a scream!! It was even louder than before!
Initially I was thinking that the seats were either 1) running on dry track or 2) rubbing on to something as the seats do “vibrate very slightly” when being moved backwards.
Either way, I have tried to locate if it was the motor, the track, or anything else that is causing the noise, but all I can hear is that the noise is coming from underneath the seat somewhere around the lower left corner (I can feel it somewhat from my left behind).
The speed of the forward and backward motion (during and not during the sqeaking) are the same.
What really boggles my mind is that why would applying grease actually make the noise louder.
If anyone has any idea on the cause and fix for this, please do let me know.
Thanks.
Television !
Dude, I have seen your replies, they are everywhere in the site and you are awesome!
But… sorry … what is a “lnk” and what should I be looking for in the ‘squab”.
Cheers!!
Television !
Cheers!!
Lets just clarify, links, if you click on the link with you mouse it will open the diagrams of you seat construction.
Your seat needs to be reomoved and fit a madified part
I can send detail of how to do this, but I need your Email address, you can take it away once I have the address
This is a link, just click on it, and it will open some more links
http://www.detali.ru/cat/oem_mb1.as...722.616&GM=716.662716.663&CT=F&Cat=45Y&SID=91
Ha ha ha.. sorry about that. Lnk = Link (did not realize the short form)
Many thanks for your help.
2 Emails sent I hope this is the fault. MB only ever use the term noises.
Please go to edit and remove Email address
