I have an S210 from 2000. Seems to suffer from the 'is it wheel bearings or is it tyre noise' at the front. I'm pretty convinced it's wheel bearings as it's a sort of rolling drone over 50mph, especially on quiet road surfaces. It's a lovely quiet car and so noises are noticeable, but also, I'd like to get it as quiet as it was designed.
I therefore had a look and there was a little play and the outer bearings and they were completely dry. I repacked with multi-purpose grease and reset the adjustment on them but not sure anything is any better. I'll give it another go as I have now bought the proper MB grease and so will clean and repack the outers but also I would like to repack the inner bearings (can see no reason why they shouldn't be as dry).
Is there any way of doing this without taking the calipers off? If I do have to take them off, should I replace the bolts or are they ok to reuse?
The car has done 100,000 miles and I'll probably need to renew the discs in the next couple of years.
