Headlamp washer stopped working W209
SwindonCLK320
Swindon
Range Rover Sport
any ideas why the hamplamp washers on a 2003 clk320 would just stop working. normally when you press the button you can hear the pump working, now there is nothing. Anyone else had this issue, is it electrical or a faulty pump? Thanks
The pipes may have come off the jets, or even just one can stop them, open the bonnet and try them and see if any water runs out from under the lining
If you can't hear the pump working, it could be broken. There could of course also be an electrical problem elsewhere in the circuit or something as simple as a blown fuse?
