- Sep 27, 2016
- Location
- UK
- Tesla Model S, Model 3 LR, Model X /// Previous: Jaguar XFR, Mercedes E320 CDI, C32 AMG, CLK 320
As a lot of people on the forum have older cars which are often plagued with the clouding headlight problem I thought I would post this.
Yesterday whilst looking on Amazon I found the 'Quixx headlight restoration kit' -and as it was available for the bargain price of £10 I thought it was worth a shot.
This kit requires no extra tools or equipment, everything you need is in the box. The benefit of this kit compared to others is that it includes a 'sealant' which is supposed to prevent the problem recurring which is extremely easy to apply, simply spray some on (it is like a gel like texture rather than a aersol) so no risk of overspray etc and it is simply rubbed on with the cloth and buffed off once it's dried. They recommend to reapply it every 3 months.
My headlights had a few scratches before so I thought I would use this kit.
I took my time and followed the instructions on the kit perfectly. Ensuring to mask around the light ( I had no masking tape to hand so used some brown packaging tape ensuring the spray water on the paint before to essentially make it 'low tac')
I then proceeded wet sanding the lights with 2000 grit, 3000 grit and 5000 grit sand paper using the sanding block provided.
Whilst the rubber block and sand paper was small, it works well and it was a small issue seeing as the kit only cost £10. If this is an issue you can buy your sand paper seperately.
Then you apply the Quixx plastic polish, and polish it to a high shine. Following this the sealant is applied.
Pic of scratches before:
Mid-sanding:
All done before washing:
Cheers
P.S the cheapest place to get the kit is on amazon, and they offer next day delivery (in my case same day!)
Mid-sanding:
Cheers
