Heated seat question help with e bay part
lynall
Kent
The silver one.
This is on e bay and finishs soon and i am not sure if its the correct part
http://cgi.ebay.co.uk/ws/eBayISAPI....m=330282737138&ssPageName=STRK:MEWA:IT&ih=014
I am not sure if its the cover you actually sit on or the base foam cover which has the leather over the top.
The part number is on the russian site but says fabric but this seems to apply to all models even though this part is listed for the elegance model
http://www.detali.ru/cat/oem_mb2.asp?TP=1&F=210270%5F65S&M=113%2E940&GA=722%2E623722%2E632&CT=F&cat=65S&SID=91&SGR=060&SGN=01
Basically being a tight wad and thinking this might do the trick:D
Sorry part no from e-bay is A210 910 4546
Ta
Lynall
It's a fabric outer seat cover, the bit you sit on.
They also contain the heating elements.
Unless it matches your seats it's not much use to you.
Good price and reliable seller though.
Thanks for the reply Nick i had a feeling it was to good to be true:p , was not sure on the cover part as it looked very rough finishing at the front edge of the cover hence the reason i thought it was an under cover.
Lynall
