Quote: "How did you diagnose the HVAC / AC Control Unit is faulty?"
Left side min heat.
1. Swapped leads at Duo valve. LH vent hot RH same as left before.
Proved duo working, controlled by RH controller .
2. Swapped leads on thermisters (in SLK behind unit into heater) still no heat on left. (to see if one faulty) RH still OK
So control unit...
Opened, cleaned, resoldered, checked and cleaned potentiometers
Still min heat on left.
Bugger
Bazzle
