I bought a 2004 E Class Estate 2 months ago with an Audio 20 unit and 6 CD changer, plus Nokia phone cradle, to which I added a Viseeo MBU-3000 Bluetooth kit. Since owning the car I have experienced the following intermittent problems:
1. CD changer not working - when you press the CDC button the screen implies that it has switched to CD changer, but nothing plays. The console button to reveal the changer works, but it is not possible to insert or remove CDs
2. Screen is blank - everything works as normal (e.g. You can change radio stations), except Audio 20 screen is blank
3. Phone not working - When you press any of the phone functions on the console it displays "No Phone"
As stated, all problems have been intermittent. CD changer issue happened frequently in the 1st month and has been OK for a few weeks. Screen was OK for perhaps 1st month, but now occurs frequently, but starts working just as quickly (e.g today was blank when I started my journey, but started working after 5 minutes). Phone not working is a problem most of the time, but will sometimes all of a sudden appear in the display and phone functions will work. Phone pairs with the MBU-3000 all the time without problems. I 'm unsure if I've had the CD changer and blank screen issues at the same time, but think not.
The car is still under warranty from the dealer where I purchased it (3rd party independent). The warranty gives me some cover, but not complete. They 're prepared to send the unit away for testing and for a possible fix, but suspect that because problems are intermittent, that they may not be found. I've also noticed that Audio 20 units are not very expensive on eBay (about £150).
My questions are:
a. Do you think all 3 of my problems are with the Audio 20 unit, rather than CD changer and docking station for issues 1 and 3?
b. If all issues are caused by a faulty Audio 20 unit, is replacing unit for £150 likely to be my best option to resolve?
c. If yes to a and b, would any Audio 20 unit for a W211 work (and simply need plugging in, without any modifications)? I can see my existing unit is a model MF2311, A2118209889, but on eBay the units I've seen are model MF2770 A2118702889 and appear to be from 2007).
My questions are:
