philharve
Hi All
Has any member encountered steering 'vagueness' that appears to manifest in the C-class as the 80/90mph mark is approached? It worsen the faster you go.
I have a C230K that exhibits this phenomina. I changed the tyres for ones with better grip/wear characteristics and only this week the steering damper was replaced. It was totally knackered. I also had a pair of lower ball joints replaced because there was slight wear in one of them. The car's suspension in fine. Despite these changes all I succeeded in doing was to move the point of instability further up the speed range.
I discussed the instability issue with both my indie and a dealer and both confirm that the curious handling chacteristic is not a design flaw, it is a characteristic of the steering geometry which also affects the E-class but to a lesser extent. The S-class is unaffected: it's rock solid at speed. It's also a heavier car. My indie added that the C-class is a relatively light car and its near vertical sides mean it is prone to side winds. Older C-class models are even more susceptable to the instability issue. It has been suggested that the car lifts as it travels faster making the steering feel light which contributes to the vagueness. This would suggest lowering the car might help.
My indie informed me that MB had a procedure for altering the steering geometry if a customer complained of high speed instability. The modification meant changing the alignment of the wheels in relation to the road surface. Instability is almost eliminated but tyre wear increases.
The C-class steering is setup for relaxed and comfortable travel. The C-class is not a sports car, C43 and C36 excepted, even though its top speed is 143mph. You need the skill and responses of an F1 driver to drive a C-class at autobahn speeds. It is an unforgiving and unnerving experience for the less skilled driver.
Has any other C-class, or E-class owner, experienced vague steering which generally starts to become noticeable at around 90mph? I don't have the skill or courage to push the car over the hundred mark, even if it was legal to do so.
REGARDS Phil
REGARDS Phil
