The cost of lighting up two tail lamps is minimal , so there's no argument not to have them .
Especially if LEDs.
Especially if LEDs.
and in roughly the same vein, why do manufacturers, Mercedes included, only fit one rear fog lamp when there is a moulding in the other side to take the bulb holder???![]()
Legally only required on the off-side, so sorted for LHD and RHD. Cost saving? That said I thought most MB models had lamps fitted both sides so could be used as substitute lamps.
IIRC they are not enabled on both sides as they could be confused with brake lamps being applied....
legally maybe just one side but if that bulb fails at least the other side will be on
Which is why I said most MB models have lamps both sides and will use substitutes should one fail.
I for one have been en "lightened" by this thread...
I saw a motorbike cutting in between lanes and there was a massive camera mounted on top of the crash helmet.
I guess he/she wants to record in 4K what happens when someone decides to pull over having not seen the bike.
Quite right too, blind car drivers are a real menace
I used to see this Mad Max "filtering" regularly on the M1 near Luton. Slow moving traffic and bikes doing up to 70mph between the lanes.
Others would be filtering past cars doing 70mph already...
I saw about 4 fetched off, but still the Lemmings continued...
