How do you change OBC from Kph to mph?
mun802
Wrea Green
ML 270, Porsche C4 Cab.
The overhead OBC in my ML has always read (annoyingly) in kph. However, the other day it was reading in MPH but has now reverted back to KPH????
Does anyone know how to change it to read MPH?
Thanks.
What does the dashboard screen read in? i ask because i changed the dash computer to kph whilst in France and the sat nav automatically went to kph as well.
Lynall
As you scroll through the menu, there is a language setting, make sure it is set to English and it should switch to miles.
This wasn't possible in my W211 E Class, it would factory set to only be KPH
Sorry Guys I should have been more explicit, its the little overhead display reading not the Sat nav. Clocks / speedo etc all read MPH.
See post 3 above, I had exactly the same problem with my ML in the overhead display, you need to change to English setting. It is in the handbook, how to change the language, although it does not say that the km/miles setting changes with it.
