how to change o rings please help
zorpio
c270 cdi 2001
Hey guys my 02 c270 cdi is having trouble starting and also cuts out when you accelerate fast.. ino theres a few things that cause this
A common problem can be air being drawn in the low pressure lines - the low pressure fuel lines have O ring seals on the end of them that can go hard or split causing air to be drawn into the system - check all lines from the filter to the pumps at the front of theengine & up to the fuel rail to see if there are any air bubbles in the lines - if required replace the O ring seals at the end of the lines.
Does anyone know where i can see a video or could someone explain to me how to change these o rings myself. Thanks
