Hi all,
Fuel is getting mighty expensive these days so it seems worthwhile to spend some time and money on improving my cars fuel economy.
I have a W124 1995 E300 diesel estate (auto) (185,000 miles). I struggle to get 30 mpg for a tank (400 miles) - typically only getting around 370 miles per tank. Ok, sometimes I'm a bit heavy on the right foot - but I was a good boy for the last tank and still only achieved 31 mpg - with almost all motorway miles, no faster than 70 and no heavy acceleration at all.
Everyone else reports better mpg for these cars (even the petrol ones!). Important things: it starts and runs faultlessly, pulls well, has good oil pressure and never overheats. It blows some smoke if pushed hard up hill. There is some soot inside around the exit of the exhaust pipe. I have put a couple of diesel cleaner bottles through it but with no improvement in economy. It has been serviced regularly throughout its life and there are no obvious fuel leaks. The car is used frequently for long journeys. The breaks and suspension are in excellent condition and there is no abnormal tyre wear.
Thoughts:
+ The fan clutch seems to grip a lot when the engine is cold and the fan never really runs free - is this normal or should I replace it?
+ Diesel injectors - worth testing and servicing?
+ Injector pump - check and adjust (an expensive job) - worthwhile?
+ Caked on grime in inlet manifold pipes - worth cleaning?
Any other suggestions?
Anyone tried to improve the fuel economy of other high mileage mercedes?
Andy
Thoughts:
Andy
