OK - I'd ask them to re-do the inspection ... The threat of returning ("backing") the car is very significant to the dealer ....
R
R
For every person who doesn’t go back, then it’s a direct bottom line benefit - I suspect a surprising number don’t.The salesman told me that there has to be a minimum of 3mm on the tyres at the point of sale. The inspection report said there was 3mm, I pointed out that this was impossible as after 200 miles they were now at 1.5mm and level with the wear indicators. They said they would replace the tyres with zero argument. Then when the brake pad light came on at 250 miles I called up and told them about the pad, the salesman told me that there should be a minimum on the pads just like the tyres. It is only the mechanic who has given me any sort of pushback. I fully expect them to sort the pads when I see them in the morning, its just a shame my inspection obviously wasn't carried out correctly.
Unfortunately as has been highlighted in this thread it seems that some dealerships are doing little or no checks and if a customer highlights any problems at point of sale they are rectified and if not then the cost of preparation is almost zero to the supplying approved used dealer-good luck and hope your issues are resolved to your satisfaction.The salesman told me that there has to be a minimum of 3mm on the tyres at the point of sale. The inspection report said there was 3mm, I pointed out that this was impossible as after 200 miles they were now at 1.5mm and level with the wear indicators. They said they would replace the tyres with zero argument. Then when the brake pad light came on at 250 miles I called up and told them about the pad, the salesman told me that there should be a minimum on the pads just like the tyres. It is only the mechanic who has given me any sort of pushback. I fully expect them to sort the pads when I see them in the morning, its just a shame my inspection obviously wasn't carried out correctly.
I dropped the car off this morning and they just called me. They have fitted the 2 new tyres and are fitting new brake pads all round. I must say I'm pleased with that outcome, there was no arguing from them at all.
Good news-it’s a shame you had to go back and ask when it should have been done before going on the forecourt but at least it’s sorted now.I dropped the car off this morning and they just called me. They have fitted the 2 new tyres and are fitting new brake pads all round. I must say I'm pleased with that outcome, there was no arguing from them at all.
Only the form was inspected, after a box ticking exercise.clearly nothing was inspected
Back when the W123 was current , a friend bought one new from a dealer not far from where you are .This ^
Mine went from 7mm , according to the techs video, to pad warning light in less than a month (200 miles) , so either someone was "tracking" my car during the night whilst i was sleeping or they were not checked properly (at all) during the service , my ££ is on the later.
They definitely never checked the air filters / pads / and probably never replaced the oil or the brake fluid either , which i couldn`t prove.
The above "thorough" servicing was carried out over four years and at a reasonable cost of £2k through their service plan.
K
