Hi All,
2006 CLK 320 cdi, 722.9 (7g tronic) 99k. Gearbox oil changed by Mercedes (at my request) about 5k previous.
In the last couple of weeks, the car has developed a weird rotational noise. The car shifts perfect in C or S, but under heavy load, there is just this weird sound. It got ever so slightly louder when i removed the shifter cover. Could be either the propshaft or (hopefully not) from inside the 'box. The noise does get 'harder' when i went around a mini roundabout at speed.
I don't have much access under the car, so managed to get the covers off and have a look. The flex discs both look fine, and I couldn't immediately see anything bad.
Granted noise related questions are difficult to answer, but i'm super stumped at the moment!
EDIT: I should add that i've also tested coasting in neutral with the engine off - noise still apparent.
