This BMW was taken in Ireland a few days ago, keyless entry signal was amplified by the “breadboard" thing held by one of the thieves in the video.
See… https://www.facebook.com/jennifer.s...008496604438/1572869436339595/?type=2&theater
Dec
Naturally, I keep our cars in a lead-lined garage.
Interesting but I don't think its the whole story. He gained entry using the time honoured method. Very low tech, I can mange that on many cars. If they had "amplified the signal" sufficiently to start the thing, they would have simply lifted the door handle to get in.
The post as far as I have read does not say it was keyless entry ? if that's the case they may have picked up when she transmits using the conventional pinger which is generally technically easy .
No idea what the breadboard thing is but I can assure you the keyless entry signal on my wifes car does not penetrate our house walls (the passive signal dies after about a foot) so he could have amplified fresh air all night outside of ours
When my key is within a range of about 20-30 metres e.g. in the house/car on drive or parked outside friends house, small carpark and I'm nearby, I simply deactive the keyless by pressing the key's lock button twice (after locking car)
Once the key is deactivated it can't be amplified.
If I'm in a large car park and I'm a distance away e.g. Westfield I don't bother deactivating
Ditch, can your wife’s key be turned off?
Dec
I didn't know you could turn the key off, I think ill give it a go later. The thing is if they want your car bad enough they are going to get it, you can make it difficult but do you want three or four scrouts with weapons waking you up to ask for the key's. My son's boss had that happen to him for a Porsche and his wife is still receiving therapy and refuses to stop at the house..
The thing is if they want your car bad enough they are going to get it, you can make it difficult but do you want three or four scouts with weapons waking you up to ask for the key's.
