Keyless go - button on gear stick
smillion
CLS350 CDI sport
What would happen if i accidentally pushed the Stop button on the gearstick while travelling? Will it sop the engine?
Marc
Try it :)
No, you're fine
Marc
The keyless go on the E will only switch the engine off if it is neutral or Park...
I presume the reason you can turn the engine off using the keyless go is that if something goes wrong on the motorway and you need to turn the engine off and coast to a stop
