flango
Hardcore MB Enthusiast
Has anyone done an LED headlight conversion by straight swap out of the bulbs? If so what bulb manufacturer did you use also what wattage and lumens. Did you get heat accumulation problems at the back of the bulb giving shorting issues etc.
Don't want to get into the legality debate as have already discussed with VOSA and as long as you choose the correct cree led pattern for use with either reflector or projector type lamps there is no issue.
All comments on performance welcome
TIA
TIA
