Linguatronic retrofit for W164 advice needed
hercules
Kent
W203 2006 180K Sport Edition & ML164 sport
I got My hand on a linguatronic Module for my 2006 ML , and need some help for parts needed to make the retrofit possible. I know I need to replace my existing steering wheel buttons .
I do have the UHI installed under the rear seat.
So what other parts are needed and what is the procedure ?
Do I connect the hands-free microphone group to the VCS unit?
Yes the microphones connect to the VCS controller AFAIK. You will also need power, wakeup and MOST fibre to loop it into the ring. The buttons for the wheel will be the most expensive parts to buy.
Thanks Alfie,
According to WIS Mic 1 and 3 goes to VCS, I know where to connect the wake up line and ground ,power goes to fuse 20 .
do you happened to know the part number of the connector for the VCS and MOST connector with the short fibre optic
Thanks Alfie,
Do you think Comand on line can supply me the necessairy harness, connector and fibre optic.
OK , I'm getting somewhere now, I managed to get a nearly new steering wheel with buttons on Ebay for the price of one buttons unit from MB UK, fitted today.
I have the harness, F.optic and control unit and as soon as the weather get better I will finish the retrofit.
How does one activate Linguatronic
How does one activate Linguatronic in a W220 with MOST? It was originally built in by the factory but now shows as "not activated" in Comand.
Do I remove the back seat, unplug the linguatronic unit and then connect again after 10 seconds? Is that enough?
A guy at a MB garage told me it could be "poor power supplpy to the unit" and that he needs to check it with Star for one hour at £100+ ... and then MAYBE have a solution. Surely I can do something myself first?
It could have failed (the VCS unit in my car failed), but normally if that happens the phone system has no microphones, i.e no sound for remote end.
It does sadly sound like it needs to be diagnosed with Star. But, I would certainly try your solution first (unplug and connect again after 10 seconds)
It could also be that the ring order is wrong in the AGW so COMAND is ignoring it ..
Richard
hi hercules . i am thinking to do the same , buy steering from ebay and fit it ,
was very difficult job to do??most of the steering wheels come without airbag , will i be able to use the airbag from existing wheel ??
pls reply .thanx. eddie
Yes should fit but you can get the buttons for your wheel without having to get a whole new wheel.
Its far cheaper that way.
Sorry Eddie to be late for reply , but some how I did not get notification of your question. but Alfie is right, yes it will fit.
Retrofit finished without problems ......so far. :bannana: :bannana: :bannana:
Thanks to Richard, Alfie and Diesel Benz
