merc man
- Mar 8, 2006
- Location
- London
- Mercedes C180 kompressor,CLK V6,Fiesta ST,Rs Escort,IS200 Sport,Renault Clio V5
hi there,
After so much trouble with my W203. I decided to find all the ground points i could and check them all for corroded or broken wires, as my scanner pinted to a short to ground, none found and all were fine, checked every fuse (all 3 fuse boards) and replaced a dodgy looking fuel pump fuse.
I then went back to the front of the car and i recall that when the car was repaired a few years back there was an issue with the passenger fog light and the fan not working, leading to the car over heating, this was rectifyed by the repair centre (over 4 years ago).
I took a look to find a mass of black electrical tape, so off came the wheel and the plastic arches and the bottom protective plastics,
I then took apart the tape to find all sorts of fixes to the wire/s and a live wire had a gash and corroded, so i cleaned it and taped it up individually and re-did some of the wires which were ground points.
My main problem is that there is a black wire with a blue stripe, its near the bottom washer bottle on the passenger side, it has a ground wire which is fine but the wire is just sitting there, it has a current going to it 0.045v on my multi meter. but i cant find the end where it should connect to i hae looked every where for about 3 hours but no luck, it comes out from a big loom and has no connection, i presume it was damaged, and simply cut to tidy it up. it may be the cause of my faults and im sure that the wire should not just sit there, the insurance say that its been more than 3 years and therefore it is not covered. At this point i just want my car to work like it should, a wireing diagram would be helpfull or where the wire should go!
thanks in advance
thanks in advance
