goblintinkerer
symptoms there since owning the car. 120k miles FSH. at idle engine speed around 650rpm hot or cold there are engine vibrations often in the cabin. as if it turns into a diesel engine for a split second. it almost feels like a misfire but it isnt. checked smooth cylinder running data with obd tool and for reference value 0 to 2.5 is normal, 7.5 to 10 is a misfire. mine hovers often in 3-4 multiple cylinders sometimes goes up to 5.50. coil packs were changed as preventative maintenance, no difference. changed spark plugs to ngk IFR6D10, engine sounded a little healthier after. i tested ignition leads resistance w multimeter theyre all came ok. i connected all back with audible click. engine wiring look fine no corrosion or bad bends. pcv hoses around valve covers are intact since i changed valve cover gaskets. dont know what to check next. bad injector? how can i check them?
any suggestions welcome. thanks
