DelDrew
- Jan 27, 2017
- Location
- Chelmsford, UK
- '19 GLC AMG 43 & '07 CLK280 Sport Convertible
Just got car back from Indy, they ran a fault report that, following a reset and test run, flagged up the following items. Any help on these would be appreciated!
P0154 - Component Y110 (three-disk thermostat valve) has a short circuit to ground (P0598)
P0406 - Component Y16/2 (Heating system shutoff valve) has a short circuit to ground (P0115)
P0426 - Heating of component G3/6 (Right O2 sensor, after TWC (KAT)): Short circuit to ground (P0037)
P0430 - Heating of component G3/5 (Left O2 sensor, after TWC (KAT)): Short circuit to ground (P0057)
P0442 - Heating of component G3/4 (Right O2 sensor, before TWC (KAT)): Short circuit to ground (P0031)
P0446 - Heating of component G3/3 (Left O2 sensor, before TWC (KAT)): Short circuit to ground (P0051)
P0850 - Y58/1 (Purge control valve): Short circuit to ground / Switchover valve permanently open (P0458)
P1066 - Relay for air pump : Short circuit to ground (P2257)
P1070 - Y32 (Air pump switchover valve) : Short circuit to ground (P0414)
P1186 - Y22/9 (Intake manifold tumble flap switchover valve) : Short circuit to ground (P2009)
