Screwdriver
- Oct 20, 2008
Couldn't PM you so here is my experience.
I sent in my W123 for a service in 2016 - he agreed that he would inspect/service/ repair all issues after conferring with me. The budget agreed to was "up to $2000." To be fair, the car's drive shaft had split causing him to breakdown enroute to Swansea.
A few days later, Cosovich calls only to insist that the car cannot be serviced and must be fully restored. He used colorful adjectives and peddled a strong sense of urgency to highlight that just repairing the car would be insufficient. After insisting that he stick to the agreed budget, Mark asks that I have my car recovered from his garage at my cost. He then threatens to charge me for inspection fees if I don't agree to restore the car with him. I should have run at that stage but I didn't.
I'm skipping over some of the gory details here, but after several agonizing calls, he eventually agreed to perform this full restoration for £8500 all inclusive. It was very difficult to lock him into the "all inclusive" term but he eventually conceded. I shudder to think of what would have happened if he hadn't. What he did not know is that I had priced the cost of labour and parts for the same job (minus powder coating etc.) which came up to around £5500. So I justified the added amount to myself because he would be bead blasting, powder coating and fixing a few additional smaller items all while providing a 1 year warranty for his work while he had the car in his care. (My W123 has SLS suspension, for which expertise is rare in the UK).
Fast forward to delivery of the car 6 months later, following completion of the work. I pointed out that the air-conditioning still did not work, the suspension made terrible noises over speed humps and a grinding noise continued to emanate from the rear. Mark grudgingly took it back and replaced the condenser as it was barely hanging on. He then proceeded to assure me that he would address the other suspension/ drivetrain noises in the new year. Mark continued to ask for more time and by this point, his 1 year warranty period had ended. Immediately after this, he highlighted that the car was no longer within warranty and that he would not repair the remaining issues at no cost. When I reminded him that he had assured me he would do this as part of the warranty in writing, he responded that I should be grateful that he did the job I had paid for, and that he had thrown in a lot of extras as part of that.
Frankly, I would have derived some satisfaction from taking him to small causes court over this, but the issues he neglected can be rectified for less than the hassle and cost of a case. I suspect but cannot prove that he may have realized this as well. I'll end by saying 3 things:
1) Mark epitomizes the following quote "empty vessels make the most noise"
2) You'll find the majority of praise comes from people who buy his book or who trust him blindly ( a colossal mistake)
3) If you want the same level of expertise for your W123, paired with absolute honesty, I'd strongly recommend Holford Motors in Hornchurch. Paul is an ex-Mercedes tech who trained on the W123 when he was in his 20s. What's more, he's a gem of a person and has rectified all issues for me. Can't praise him enough!
Best of luck and let me know if you have any further questions about any of this!
Why I've never broken down in a Classic Mercedes (in 15 years) | General Discussion
Greetings, My first Mercedes (and my first purchase) was a W124 E220, made by Telco. Equipped with heavy duty components for tropical rough roads, the car has taught me the importance of preventative maintenance. I still own it, and it runs very reliably. Since then, I've purchased a W123...forums.mbclub.co.uk
Doesn't count if you weren't there at the time then?
”Honesty” is much like being “unique” - they’re absolute; there is no “nearly” unique or “pretty” honest.It is worth remembering that dealers in used cars are only after money, some are honest some are not, when temptation is put in the way of a dishonest one to make money by misrepresenting an item they will. There is no such thing as a person who is mostly honest, they either are or they aren’t.
A case in point, many years ago I sold my r129 to a Mercedes classic dealer. The car was beautiful and had covered 70k but had a speedo change early in its life.
The dealer used the car himself for trips to Spain (featured in the Mercedes Club Gazette) before selling it. He forgot that the car had a speedo change and magically lost all of its early history, therefore, to a casual glance the car had covered a genuine c48k miles. He was found out when the new owner contacted me and asked if I’d ever had an issue with a whiny diff on the car as the dealer was refusing to rectify it. We then discovered what had happened. The dealer tried to pin it on me, until I forwarded him the e mail I had sent him clearly outlining the real mileage ( he must have also disconnected the speedo for the trips he made)
Do not give your money to someone who isn’t honest, you will regret it.
A bit like “never broken down in 15 years” is a bit like “same car only broke down while someone else was driving in the last 5 years”.”Honesty” is much like being “unique” - they’re absolute; there is no “nearly” unique or “pretty” honest.
Crikey Screwdriver, that W123 sounds like a bit of a dog!
Breaking down with spilt a driveshaft, suspension making terrible noises when going over bumps, air con not working, condenser hanging off, grinding noises from the rear........is it even roadworthy??
