mb star 2000 wisnet das cable
psprigs
Hi, im looking for a 19pin to 9pin cable for the mb multiplexer to ibm t23 serial or to my mb ibm
docking unit which has a 19 pin connector on the top left.
Or the wiring diagram for the cable, coming from a 19 to a 9, means that it prob
only uses 4 odd cables, earth, tx and rx, and live.
I have the multiplexer and other cables, just cant source this one.
Paul
Oh and hi to all as this is my 1st post.
Paul
If you send the money to RICHARD (member name) then I will post it from Australia as registered mail. Cost is 220 pounds delivered.
It uses 15 pins out of the 19.
is my DAS setup complete?
Hi, just checking what else is needed.
i have a t30 with das,wisnet the 05/2007 software on it way
i have a actia mb box with 19pin on both sides.
i have the obd cables
i have a 9pin to 19pin cable, from the multiplexer to the com port on ibm
My issue is, that some china companies are saying that you cant just use the 19pin to 9pin serial cable, you need another convertor box to hook it up 2 a serial port.... is that true? as ive seen plenty of complete standalone kits which just show what i have above forsale....
