Mercedes W114 250 Coupe - help!
Add a bit of black and a pinstripe of white - voila....
Here you go, came across this while having a general scout around. Note the V.I.N. and the hose connected to the top of the rad, looks very much like the ATM oil cooler is built into the radiator as one would expect.
That's the engine oil cooler for certain. Very similar to the later M110 engine cooler. Take great care when slackening the pipe unions as the male is fusion welded to the cooler tank and this weld crystalizes through time and snaps off with almost no effort.
Well, guess what, having just checked the oil cooler which was like the radiator already disconnected, someone has done precisely what Druk just warned about. For once it wasn't me! Another part bites the dust...
Given my main radiator needs re-coring and I still have the plan of retro-fitting an automatic box, cooling is something else I need to get my head around. There are some oil cooler pipes for the auto I would need to source too.
Been busy this morning cleaning things up.
Mudflaps were pretty filthy when I found them in the boot, although the rubber was sound.
After cleaning up the rust, removing the dirt, and the residue of a varnish, plus a little touching up of the logos, then a polish with Gummi Pflege, they are now almost as good as new.
Ivory and Cognac or Burnt Orange and Cognac interior would look nice too IMHO.
Cognac is pretty dreary in the flesh, ivory is nice, but red is best, which is what I have in very good condition.
I loved it when he switched on the Becker and out poured the Electric Light Orchestra! That takes me back.
Cor, smart place here. I have finally arrived in the hallowed surroundings of the Mbclub project section, filled with the legends, the luminaries, the loops and now the loon, a total mechanical incompetent one at that. Phwoar...
What a day. Just sitting down to a well earned cup or two of the Algerian Coffee Stores Imperial Noon blend tea (Lapsang Souchong and Keemun teas with jasmine flowers and oil of Bergamot) and some bread and the last batch of raspberry jam my neighbour Jane made before she passed away of cancer. So a red letter day. Why? because I got the zebrano veneer panels off! First the passenger side one was not easy but not too bad (the thin cardboard lining of the glovebox died in the attempt but there was no other way short of removing the dash). It is held in by two 10 mm plastic nuts. The heater vents have to be removed (from behind - first pull off the heater piping, then having removing the vent opener with a sharp pull from the front, twist the rear of the vent pipe which if you are lucky should pop straight out, then the swivel nozzle and spring, a retaining clip and finally push the plastic surround forward. The thin metal surround to the vent opener is a b ugge r to remove without bending.
With the plastic nuts undone with a bit of fiddling the wood is freed from the dash. The veneer is microscopic, the wood backing it is more supermodel than thin, while the aluminium panel the wood is glued to could pass for some turkey foil.
So the passenger side took an hour, armed with the knowledge gained I thought I'd attempt the driver's side.
All the light switch, vent opener, vent and handbrake have to be removed (from left to right).
[/QUOTE]
Off with the steering wheel which really does get in the way.
Of course, this side was absolutely dreadful. First the location of the nut between the steering wheel boss and the ignition key is just awful - you have to put your hand in from behind. Of course, this uses a 9mm nut just to be different (which you don't know when you start), and there is no room to use your hand close up so using a socket extension appeared the only way. Except the nut was so tight that didn't work. I tried everything, different socket sizes, my fingers, pliers, none got close. The heater vent refused to move and it took half an hour of fiddling and pressing before finally it popped out, then all the other bits took forever too.
The handbrake handle was easy, the light switch required the most fearsome tug and the surround needed a knife to spin it round.
Finally, in desperation, I grabbed my 9mm little torque spanner and with about a cm of movement got the plastic nut off slowly but surely. A push from behind and all done. The veneer is pretty ok under the badly flaking varnish. I'm going to see my polisher next week and ask his opinion on getting it repaired and re-polished to get the best out of the wood. The main piece looks a bit bland so I may get that replaced with some showier wood.
Allowing for a leisurely start, popping in and out and walking away when fed up, that took me all day. I banged my head trying to remove the A pillar internal trim (it should pull out but took a lot of force which then led to me flying forward when the resistance stopped), I cut my hand behind the dash on a metal cable tie, and my main socket wrench died a death as the direction control gave way taking out the steering wheel - so a new one required!
A slightly better photo with the directional light toned down
I think the w123 had that sort of wood that managed to look like plastic - the W114s that I've seen have a wood varnish proper.
Anyway I have a cunning plan for the wood!
In the meantime not much physical progress as I'm waiting for things to turn up, but I am accumulating all the necessary bits and pieces plus researching my plans. Best thing to do in this perishing weather.
Cunning plan started. Silvercrest are literally two minutes drive away (anybody ever wanting wood done there say hello if you can - I am 500 yards away as the crow flies) so I popped the wood panels from the W114 over there to discuss my ideas, which have been set in train. Nice guys, they mentioned they had Pagoda re-veneering work coming out of their ears and an increasing number of W107s. The original wood from one was there (it had been hacked out by an idiot) was pretty lacklustre too. By coincidence they had prepared a sample of the result I was after for another client so it was very painless!
Obviously I shall wait until the car is done to show you all! :)
Silvercrest has a very good reputation.
I knew they were good - Drew had some stuff done there. My polisher thought a specialist a better idea. They were doing a special commission Bentley interior with piano black cappings and a rich walnut veneer, as well as an entire new Bentley interior with far better wood than the original.
Not cheap mind...
Pop in for a cuppa Peter next time you have some time to kill near Heathrow.
