Some progress with the dizzy - which inevitably raises questions.
It is pretty much stripped, top plates removed - the (mech) advance mechanism is in view, the vac plate as free as can be, and overall in reasonable, rescueable condition. However, I cannot properly check the mechanical advance as I cannot access the drive dog to restrain it. The reason is, where here ...
...it is visible, on the one I'm working on it is within a long alloy tube with a mounting lug that obviously bolts to the engine block, extends up to the dizzy's base, and has the clamp mounted on it, so....
Q1) Am I correct in thinking the dizzy body has to be free to rotate within that tube (for timing adjustment it surely must) and therefore can (once 'freed') be drawn from the rest of the dizzy. (Anyone can come in on that one).
Q2) to CM. What exactly electrically speaking needs to go back on the dizzy?
Q3) Assuming the D-Jetronic points are not required which of the following is preferred? A) Reinstall all of it. B) Reinstall it but with the points removed. C) As B but with plastic plug removed. D) A new blanking plate (if I can find suitable material).
Q4) To fit the PetRonix(?) system, does the upper (ignition points) cam remain, have to be removed, have to be modified?
Q5) Anyone can come in on this one...In operation, the mechanical advance bob weights bear against the bodies of the return springs. That doesn't quite seem right to me. Anyone with a view on it?
Q6) Which car did that bit of rust come from?
