grober
MB Master
You might find this article useful Charles??
Gordini Project -Wheel Arch Liners
Quote:- The 2mm [ personally I would go a mite thicker] ABS plastic is lovely to work with. It can be cut with a jigsaw with a wood cutting blade, bent using a heat gun, and drilled with a metal drill bit. I sat it on a sheet of Celotex insulation when cutting. The jigsaw blade passes through, but the insulation holds the ABS and stops it from vibrating.
