hi all . recently i had problems with my auto tip box . i sent it in to a local speciailsit and they changed the wiring withinn the gearbox and did a gear box service . its been fine for say a year . occasionally it would still rev high then change gear (higher than normal ) but now it is more serious i feel . when accelrating medium to hard it will rev very high then stay out of gear . sometimes while coasting i can put it into neutal and back into drive , but it will be in limp mode ( not allowing me to apply power and not allowing me to change gear ) but more worrying it does also rev high then go out of gear then the car engine will turn itself off completely . just happend to me twice this morning , so while coasting i have to select neutral and turn the engine back on and then select drive. it is overdue a b service and will get it booked in on monday . one of the times it did it the epc light came on . also i have been to mercs 2 weeks ago for the recall . ( think it was a block replaced on a sensor -epc i think ? ) any ideas ??
have heard some people saying the plates need replacing and also oil traveling up the wiring loom in the gear box ? need to check oil level .
cheers shaun
cheers shaun
