currycowboy
- Oct 5, 2013
- Ml 270
Have issues with ml 270. Stripped rear tailgate as door will not open via central locking can only override by manually throwing switch. Removed servo/actuator put 12v across and throws in both directions. so appears functioning correctly. When wired up if I manually close tailgate latch with tailgate open and operate key fob you can see the servo/actuator working for the lock position but absolutely no movement for open. Guessing relay but have no idea where or number. Wiper does not operate by switch on dash, so no power to rear tailgate for these items. Please help
Also if you happen to have knowledge re ac unit, I am having water appear in passenger footwell when ac has been on and it ends up absolutely soaked. any ideas am thinking pipe blocked for "condensing side" but don't know why it would end up in footwell. again please help
