Okay just a quick post in hope rather than expectation.
The Toyota IQ (Panasonic based Nav/audio system) is throwing up a quirk in MP3 track order:
It ain't always correct - one of the following happens:
1 - All OK
2- Out of order, this is not as you would think - it isn't in alphabetical order from the FILENAME, neither is it in order from the ID3 TAG.
e.g. Track is tagged number 14, alphabetically would be 11 but in actual fact appears as "file" (The system uses the term file - significant?) and in position no. 9.
Tried the usual such as erasing all tags, re-writing etc. The obvious solution is to start the filenames with 01,02, etc - slightly annoying as the system allocates its own leading number so I end up with "1 01 title.mp3".
Finally - I know the system is reading the tags as it identifies Album, Artist etc.
I presume the unit isn't arbitrarily placing the file in this position - so just a question of finding the logic behind it.
Mike
1 - All OK
Mike
