Really? Do they use some telepathic process to adjust the engine so that at a steady 70 it uses less fuel with them on the accelerator rather than cruise.Sorry, you are wrong on this one.
Anyone who still has usable brain is smarter than your cruise control.
I'll have to agree to disagree with you also.
Russ
At steady speeds with the CC on, fuel will surely be metered out in the least possible quantities, whilst maintaining a constant engine speed.
The word brisk to me means quickly or lively. To get up to the speed we are happy with then Cruise Control will accelerate 'briskly' which means putting far more fuel into the system and then when it reaches the desired speed, if the vehicle starts going down hill, the stem will regard this acceleration, thus wasting all the fuel that was needed to briskly get up to the designated speed. Those of us that use forward observation will see that the road is about to gradually descend and make allowances for this."avoiding the vigorous resumption after a significant reduction from the set speed."
Except that all the serious advice on minimizing fuel consumption recommends getting up to the desired speed briskly -- briskly, rather than flooring it. It seems to me that this is exactly what CC does.
Do you think Top Gear just decided to drive from London to Scotland & back on a full tank of fuel without researching or analysing how it was likely to turn out?
But nobody, cruise on or off, does bang on a steady 70. Your speed will always be fluctuating slightly 69.9, 70.2, 70.1, 69.8 etc (still a steady 70 as far as the speedo goes though). And CC and a human have different feedback loops that they use to make minor adjustments to the throttle.Really? Do they use some telepathic process to adjust the engine so that at a steady 70 it uses less fuel with them on the accelerator rather than cruise.
All physics should tell what brain they have left, that doing a STEADY 70 will use the same amount of fuel.
Then the driver would not be maintaining a steady 70 would he? So very annoying for other traffic to follow someone endlessly speeding up and slowing down. And definitely not what cruise is for so it is totally irrelevant.Road speed.
This is why it uses a bit more, it keeps the speed constant wheras a driver would allow the speed to dip a bit then be resumed more gradually.
Funny how some people believe a device solely invented to measure crankshaft speed, and fuel an engine to keep turning over at that speed regardless of any other criteria, can be more economical than the human brain? By all means use CC for the convenience it was designed for, but saving fuel was not part of the remit.
Russ
I don't want to continue giving opinions one or the other way but the above is not right in the sense that CC is not making use of the crankshaft speed. A modern CC is built into the engine ECU and gets all other info like from ESP about cornering etc. etc. .
The fact is, it is only there to keep the engine rotating at the same speed, nothing more, nothing less, it is simply a convenience feature.
That sounds like just using a good old fashion Watt's govenor as a crude CC, they must have moved on pretty quickly.CC was invented in 1945, it measured the speed of the crankshaft and kept the engine turning over at that speed, regardless off any other criteria.
To my knowledge the majority of systems still work on the same principle.
It's linked to the road wheels, not the crankshaft. The engine speed does indeed vary according to load and gradient.
