Discussion Starter · #1 ·
New Member, Help needed please. My 1989 300SL won't start It has been off the road for 5 years. Things I have done so far:- 1) Found fuel pump relay, removed it and cover no obvious dry joints. 2) jumped terminals 30 & 87, 12.4 v at disconnected pump cables, only 9.4v when connected and no noise. 3) Removed bracket with pump filter and accumulator, replaced pump cleaned it all up and painted bracket then reconnected. Also drained all old fuel and replaced with new. 4) jumped 30 & 87 ,pump running 5) No Start. 6) Will fire with carb cleaner in the intake so assume ignition side OK. 7) Removed injectors cleaned exterior and then used a diesel cleaner on the inner, all gave a reasonable spray pattern. 8) Still no start. 9) Removed all pipe connections to fuel distributor fuel rises in all the distributor wells at same rate when depressing the plenum. 10) Haven't got pressure testing kit yet it is on its way however able to test flow from injectors at 5 & 6 They can be turned into a space,. Both injectors dispensed fuel with good spray pattern. 11) All back in place on turnover started and ran for v short time with big backfire then only the occasional kick but still no run. I think the initial run was due to residual fuel from previous testing still in the cylinders.
I am not sure where to go now, all advice gratefully received.
SaveShare
SaveShare
