Hey all,
Finally got the car on the 26th. I wasn't in the best of moods when the seller rang saying the car is not running right and can't really be driven. I had however learnt lessons off the old car and suggested the fuel pressure regulator was replaced. As he had a 500SL next to it he swapped over the part and voila most the problems went away. She was still misfiring quite badly when hot but removing the distributor caps revealed lots of moisture. Also swapped these over and the car now runs great.
On the plus side the car comes with a full service history and full set of keys along with all the manuals and service receipts! Can't believe it, history from 900km in 1992 to 240,000km now. The car now has approx 245,000km on the clock. This is very rare for Japan and service stamps at the same place show it could have been a 1 owner car. I even have the original bags and accessories from Yanese who supplied the car in Japan along with the Becker radio booklets and codes. Fantastic history !
So after checking chassis and engine numbers and confirming the car really was a 500e with the 'right stuff' under the good, the deal was done and I began my trip down South. Always nerve wrecking in a new car but I have breakdown cover worst comes to worst (not that I want to use it). Luckily she ran beautifully the whole 300 miles back to London. I did have an issue with the throttle towards the end of my journey but it seems to have sorted itself out now (for the time being). Love this car more than the last one, can't beat an old school Merc in black and she is in fantastic condition, I think the whole car has been painted in the past as I cannot fault it. Anyway, I’ve given it an oil change along with air filters and plugs when I got it home. I am back off to Dubai shortly so will leave it parked up for a few months until I get back. I took the alloys off as they were clearly too big and wrong for the car and fitted a set of period AMG/OZ 17" rims from Pupsi as he sold his E500. Also picked up a MB OEM fridge and some LED rears, no plans to use the LED rears though so give me a shout if you're interested in them for your w124.
After driving the car around a fair bit I’ve noticed a few issues which need sorting. The steering is creaky (any ideas?), alloys are bent on the lips so vibrate on the motorway, exhaust pipe needs tidying (I have bypassed the back box and fitted a fabricated pipe - sounds fantastic!), rear boot light doesn't work, drivers sun visor light doesn't work, car needs full laser wheel alignment and it certainly needs a tune up from a service point of view. The iconic SLS has been deleted (doh
) in favour of a brand new set of Bilstein high performance shocks all around. I'm considering refitting the SLS shocks and getting new ones from MB as all the pipework exists so it shouldn't be too difficult to put back to stock. I like keeping cars original.
In way of modifications the car has uprated suspension, set of bi-xenon / HID headlights, aftermarket flip out Panasonic TV/DVD stereo, retrofitted air conditioner in the rear parcel shelf, aftermarket LCD sun visor and a few other camera detectors etc. which are content in speaking Japanese while I’m driving. I think mostly all of this will come out but that is a job for summer when the weather is nice in exchange for a simple and period-looking Bluetooth stereo, Rainbow speakers and a nice subwoofer. Apart from this, the car is remarkably original.
Once I’m back the first thing to do will be to have the car booked into a specialist who can look over the entire car, bushes etc. and come up with a plan to have it mechanically sound and strong. I aim to replace anything looking tired.
At the moment, the plans for the car are as follows:
Service parts - all genuine MB parts
Fuel filter
Distributor caps
Rotor arms
Distributor insulator caps
Engine intake hoses
Distributor cap covers
Ignition lead set
SLS fluid tank and accessories
Coil leads
Gearbox mount
Wiper blade
Rear boot trim plastic (current cracked)
Airbox rear bolts
Airbox front clips
Rear backbox bolts and gasket
Dipstick
Brake discs
Brake pads
Brake sensors
Headlight wiper blades
Set of nib 1 spring pads
Other parts (non MB genuine)
Deerfield metal brake hoses
ITG airbox filters
Work to do
Replace coolant
Repace brake fluid and full bleed of the system
Replace differential oil
Repace gearbox oil and filter
Repair front and rear console wood trims due to cracks
Repair leather peel on centre console box and driver’s door panel
Repair drivers side mirror handle (snapped off)
Replace gearknob
Replace steering wheel with leather/wood wheel
Replace fuses with brass ones
Fit orange indicators, side repeaters and rear lenses
Fit rear LED number plate bulbs
Fit short number plate for rear
Fit ASR defeat kit - mount switch in centre console
Fit H&R lowering springs
Fit metal brake hoses
Fix boot light (does not work)
Fix drivers sun visor light (does not work)
Fix wheel alignment
Investigate steering issue
As I will be getting the wheels completely split and refurbished (black centres with polished lips and black bolts), I will also be getting a few other bits done and few areas of the car painted in the body colour at the same time while the car is in the body shop:
Bodyshop work
Paint headlight wipers
Paint grill insert
Fit, paint and wire in rear spoiler (Lorinser item, has brake light)
Fit and paint rear plastic boot trim
Refurbish split AMG OZ alloys - colour coded centes and polished outers with black bolts.
Fit new tyres (still figuring out what size to go with)
Fit nib 1 spring pads
Repaint front and rear brake callipers and backing plates black to freshen them up
Once this is all done the car should be looking really good - I aim to have this lot all done over the summer (ambitious I know) but I like to work on my cars quickly and have them ready ASAP. Please post your comments and suggestions, looking forward to hearing them
Not managed to take any decent photos unfortunately. Weather has been horrendous + black car means I've not had a chance. I will do though once the weather improves.
Cheers,
Bill
