New problem after ATF change w208
sattie
CLK 320 Advantgarde Convertible
Finally managed to get the ATF changed, resolved the problem that I had with jerky gear changes and over revving when changing gears. Now faced with another gear problem, only when braking and the gear changes downwards from 2nd to 1st I'm getting a little jerk just before it stops, very irratating. Before the ATF change a full diagnostics was done on the car just to make sure that the electro plate was not faulty. I had a leaking gearbox hence ATF change.
Any ideas???
TIA
