newbie needs help clk320 cutting out
stepheboyz
cls55
Hi all can enybody help , just bought a clk 320 , it starts fine from cold , and runs great but , somtimes when i stop at junctions it cutts out , putting in back to neutral and it starts again , is there a problem with there cam or crank sencors or choke vacum , realy not sure , any advice would be great
thanks
where would be the best place to get one ???
if it is the cam sensor where would be the best place to get one ????
It does sound like a crankshaft sensor issue.
Get them from ECP.
When cam sensors are failing the car will often start when cold but will fail to re-start when warm. Sound like it might be a culprit.
fingers crossed
order crank and cam sensor, should know in a day or two , fingers crossed , will keep u updated
Steph
