noisy feul pump on rl 129
madbonky
Heathrow
R129 300SL, ML 320, C240, CLK 500 CAB, W203 ESTATE W126 500 SEL R129 320
The fuel pump is very noisy on my 1991 300sl, i have replaced the fuel filter hoping that may have been causing the pump to strain but this has not solved the problem.
I listened as close as i could to the pump and am guessing it was the lower pump that was the noisy one, is there a way of flushing it or do i need to replace it?
By the way why are there 2 fuel pumps and what causes a pump to become noisy? Is it a precursor to the pump failing?
Jay
take off the pump and put the head in a bowl of diesel and run it backwards,, that will clean it out
