S350L
- Jan 1, 2016
- Mercedes
Thank you for that. I just checked and it says that my car is effected and that the status is open.See here:
MB Recall Check
MB Recall Check
It depends upon operating conditions, ranging from a loose leaking exhaust aft of the turbo, to DEF fluid not up to the the specific gravity in the tank, Cat plugged up with soot , excess DEF fluid crystalized in the the SCR Cat et alI had a recall with regards to the software update, would this prevent the Nox issue, or are they not related.
Well most likely your OBDs code reader can't read the faults..So. After putting my chassis number into the Mercedes website, which said that I need a software update, my mercedes dealer said that my car does not require an update.
Furthermore, my car's adbule counter is on, as is the engine light, however, when I put the obd2 reader on, there are no fault codes !!!!!!
Any ideas or suggestions?
Just picked the car up. Two new NOx sensors installed under warranty (no idea if they would have done it as goodwill if the warranty wasn't there)My car, 2012 ML350 55k miles, is going in today with the Check AdBlue message, engine warning light and countdown to not starting. It had the software update about 5k miles ago, no idea if it is related. Bizarrely, although I have not driven it much since the warning started the fuel economy seems to be improved AND the start stop goes green far more often. I would have thought the start stop would be disabled by a warning light (every other characteristic of the car seems to turn it off).
Fingers crossed they know what they are doing with it and that it is covered by approved used warranty.
Any joyContacted MB UK HQ today, and waiting for a call back from the dept ( yes, they have a dept) that deals with emission complaints
Saw some legal firm ads like
Join the Mercedes-Benz emissions claim today by Leigh Day.
Anyone tried it and are they really helpful?
I actually have 4 cars that "could" qualify if ever I decide to join one of the many claim agents - MB are really testing my patience recently.
