OBD II socket
Dieselman
Banned
Peugeot 403 Convertible
Does anyone have an OBD II socket and appropriate wiring available for a W210, preferably with as much wiring as possible to the 38 pin DTC connector.?
If you want the pin numbers and what they do I have that. If you PM me with your email address I may be able to send you a hard copy
WHat are you trying to achieve
I have the part numbers (somewhere!) for the proper ODB-II mercedes socket and some pins
The US cars have an OBD-II socket, and a gateway module,(dependant on age) that makes the engine management communicate with OBD-II protocol - but the cars still have the 38pin connector for diagnosis of everything else
R
Hi Dieselman
Are you thinking of buying a ScanGuage II? I have a 38 pin to OBD II lead but i am waiting until i get the ScanGuage to see if it works before buying an extension OBD male to female lead.
I got my 38pin to OBD from http://cgi.ebay.co.uk/ws/eBayISAPI....m=120206982771&ssPageName=STRK:MEWN:IT&ih=002
extension cable can be got here http://www.obd2cables.com/products/
230k
Thinking about it.
You need to know which pins are connected on the 38 pin plug as some are set for OBD 1 not OBD 2.
If I do this I was thinking of doing a proper installation for the OBD socket.
R
The p/n would be good, a scrapper OBD socket would be even better.. :)
I've been investigating and am not sure the gateway is required for two reasons.
People do seem to have been able to attach a line to pins 4 and 15 to obtain output, though I'm not sure which reader they are using, possibly carsoft.
The ECU appears to have a direct ISO-K line output on pin 50 but not sure where to obtain an L line from. (if necessary)
Can someone lookup the connections for the X11/22 OBD2 socket. for a US E300Turbo.?
Hi
I opened up the 38 pin adapter i bought and she only connects to 1,3 and 4. 1 is ground, 3 is positive 12V and 4 seems to be fuel system. No mention of K line in desilva's diagram. I doubt mine will work straight out of the box. :devil:
We will get through this.:D :D
230K
I have it of sorts and I was looking before you asked
X11/22
4 )-br --------
5 )-br M606
5 )-br/gr M104
5 )-br/ws M119
5 )-br/gr M112- M 113
5 )- rt/ws -------
N )- ws/vi M606
N )- ws/swM104
N )- ws/sw M119
N )- ws/sw M112, 113
16 )-rt/ bl M606
16 )-rt/ws M104
16 )rt/bl M119
16 )rt/ws- M112,M113
I am still looking to see if there is something of more use
Hi
Television i got your reply to the other post. Can you explain what the above post means?
Thanks,
230k
Hi
Thanks,
230k
Well I scanned the whole documents as Will asked for the wiring on the X22/11 ODB connector. I copied it out as above and it looks to me as the the pins are wired to receive info from all of the engines as
thats
what the numbers are. I was hoping that Will would have posted back, the info was foe a USA diesel 1998 on,, as ODB are data lines its quite possible for all the signals to be on 1 lead
I do have other info as to were the X22
connector
joins in the the main box
Any OBD 2 socket will do
I've just checked an A class A 168 tonight and that socket will be just fine, so does anyone have any sockets lying around.....???????
