RBYCC
- Aug 8, 2007
- Location
- REHOBOTH BEACH DE USA
- 1971 280SL, 1988 300CE TT, 1994 E320 CAB, 1999 AMG C43, 2005 AMG G55K 2008 CLK63 AMG BLACK SERIES
And coked the valves up. Coking is a result of spraying the petrol onto the back of the valve to cause evaporation, not oil vapour.
Can you provide proper analysis data to show that removal of breather fumes improves performance or longevity?
If by your hypothesis coking is the result of spraying a clean light hydrocarbon (petrol) on the back of the valve then what would a vapor of oil contaminated by 50% water and other corrosive agents created as the by product of combustion do to the valve?
Not sure how old you are but pre-emissions concerns, the internal engine pressure that creates blowby was relieved by a road draft tube in combination with valve/cam cover breathers.
Now using common sense what would give better performance and combustion:
a) clean intake air
b) intake air contaminated with oil and other byproducts of combustion.
The oil separator has a great deal of validity especially in industrial diesels.
In these applications the separators are much more sophisticated.
http://www.solbergmfg.com/ViewSeriesDetail.aspx?SeriesId=145
In fact Volvo thought it important enough to include it in an engine design in 1991.
http://www.motor.com/magazine/pdfs/072001_09.pdf
You being "Dieselman" should be aware that most of the research on oil separators is being done on diesels.
Apparently you're not up on your "reading" of current diesel technology !!
How about an SAE paper..you can purchase the paper if the abstract is not sufficient for you !!
http://subscriptions.sae.org/content/2008-01-2687/
How about what Cummins thinks is a good idea..
http://www.fleetguard.com/pdfs/product_lit/emea_brochures/LT36168.pdf
Is thi a shocker...excerpt from the SAE paper linked below:
"The inflow of oil mist particles contained in blow-by gas into the intake system worsens emissions. A higher performance oil mist separator system is required to meet emission regulations which will inevitably become stricter in the future."
http://subscriptions.sae.org/content/2000-01-1234/
And guess what VW builds into their TDI engines..an oil mist separator !!!
http://www.hengst.de/conpresso/_rubric/index.php?rubric=Automotive_OE__Cylinder_Head_Covers__Volkswagen_EN
And more...
http://www.mahle.com/MAHLE/en/Products/Air-Management-Systems/Crankcase-ventilation-systems/Oil-mist-separator
http://www.hengst.de/conpresso/_rubric/detail.php?nr=5420&rubric=Press__Press_releases_EN&PHPSESSID=84709eac3f259d67e05266e3037ef7b6
By your standards and beliefs it is pure folly as you fail to apply basic common sense....
High performance or engines pressurized by a turbo or supercharger need them even more as if the engine has a blow by problem it could seriously damage downstream components..
Continue to live in the dark with belief that contaminated corrosive intake air is good for your intake valves..
And as you do you will hopefully discover that oil mist sperators are being mandated by the USA and IEC as standard equipment to maintain a higher emissions standards..
Sometimes "us gearheads" lead the way with a performance mod based on "common sense" which the engineers embrace !!
