300-24, saloon and coupe, E300 24 valve diesel estate
Easy Peasy, stand in front of your engine and look down the right hand side at the back of the block. You will see the oil filter. Under the oil filter is the oil pressure switch
Hi guys, I'm new to the group, I replaced the sender unit which is situated below the oil filter.....dam hard to get it off. But any way back to the point the oil pressure still reads 3 when the key is turn to position II (dash lights are on but engine not started) Any ideas?I have checked the single wire plug and it seems to fit ok. Do you think the sender unit is not earthing properly. Its an old 260E F reg...got it free so I cant complain
