SilverSaloon
- Mar 16, 2004
- 1994 W124 E300D Estate, 1985 R107 280SL
hi
i have reassembled my lift pump but i'm now concerned whether i've done it correctly....
i have serious vaccuum now in the tank and the fuel is getting sucked back in.... i wonder if i've fitted the non return valves in correctly.
how many loose non return valves are there in addition to the one "sealed" in the outlet port? 1 or 2?
i have fitted one loose one to the end where the outlet port is. should i of put it where the inlet port is i wonder....?
see attached diagram and let me know which one is correct, A, B or neither?! i'm not convinced by 'A' anymore, as i cant see how the loose non return valve at that end really does anything.....
Its currently assembled as A and once i get it started it does seem to run ok, but due to the tank vaccuum all fuel has gone by morning.
cheers
derek
cheers
derek
