alex300ce
- Jun 21, 2012
- Location
- Wisbech
- W213 E350d PP Sport, E36 AMG sold C32 AMG sold A200 Turbo
Hi, just wondered if anyone has had this problem or encountered it before as can't seem to find any other posts with this problem!
Got a ml270cdi 2001 w 130k on clock, couple weeks ago when stopped at the lights the park brake warning light and buzzer started. As I pulled away the car would not shift from first gear. Pulled over and switched off and on and all was good. Then couple days ago happened again but could not get it to clear by switching off and on, the only thing that seemed to cure it was about a ten min wait. It then continued to do this every 5 miles or so, if it came on whilst doing 60 or so, it would then not shift from 5th gear. Have checked brake fluid and it's ok, also the handbrake switch and that looks ok to. Any ideas on this would be a great help before I take to the garage!
Also happens now on way to work after about 10 miles always, luckily only go 11 so not to bad for last mile!
Thanks in advance!
Thanks in advance!
