Parking sensor and fault code on E class 211
A210AMG
England
Hello
I have a fualty parking sensor and this is causing both front and rear to play up.
The faulty one is a rear one according to my indy and my car is an S211 (estate) so they look to be easy..ish to get to?
However and if easier I will just book it in, but I just looked on flea bay and the senosor I can get for less than £20 coloured. However I need the fault code removed...
Can this be done with a plug in fault meter you can buy or just star?
Its more that its a little trek away just to get this done and if I can fix it easy enough all the better.
They are a piece of cake to change, with no tools required - 1/2hr max.
DIY then worry about the fault code at service time :thumb:.
You don't need the code to be removed. Just get it done at next service. The sensors are plug and play
Does anyone know the code I need for the part?
I just looked on the bay and the one that said it fitted when I chose my car it doesn't.
Its a S211 2003 E320Cdi it has 4 sensors in the lowest part of the trim of the bumper
