part number required for ANTENNA up down switch W124
MBK
Hi All,
I need the part number for a the Antenna up/down switch.
Thanks,
K
I didn`t know there is a switch for the antenna
There isn't an up and down switch as such-- the electric aerial is activated by a direct signal from the radio when its switched on via a wired connection ( colour code convention for this is normally blue AFAIK) What you can do is put a switch in this line to prevent the aerial going up if the tape/cd player is being used rather than the radio. Any standard 3/5amp ( rating isn't important since very little current is used) car accessory switch will do -Halfords sell them.
Wouldn't hurt to blast through the parts catalogue for something OEM looking though would it? :) A taxi or truck-type switch from the period would probably do :)
Absolutely- If its going to be in plain sight its a must as you say. :cool: I was influenced by the fact I hid mine inside the storage compartment between the seats.;)
i found this pic of the switch...
is it an OEM switch?
I think I might still lose some sleep over that actually :o
the switch is to allow the driver to lower the aerial and have it at different heights when the radio is on.
