LvR
[FONT="]I don’t profess to know all the different scanners on the market but ...............
O2 B1S1 and [/FONT][FONT="]EQ RAT B1S1 1.999 imo refers to the Bank1 fuel trim values derived from the upstream O2 sensor.
There should be similar values for bank 2 IOW O2 B2S1 and [/FONT][FONT="]EQ RAT B2S2
To me it looks like possibly percentages are getting reported for those? ..............
............ if so that motor's mixture control for bank 1 seems fine imo (based on the small and close to 0 values reported).
Lets hope you can get to the same values for bank 2 ........................ and if bank 2 is similar then the motor as a whole is under fairly good mixture control and the ECU seems to be doing its thing.
If you can get close to the same values (of those parameters) for both banks under a range of different driving conditions the engine mixture management imo is fine
You will have to study the particular scanner's documentation to make sense of the rest of these parameters .
My guess:
DTC 0 - no faults logged.
IAT is inlet air temperature - 38C seems high unless the vehicle is standing idling.
MAP is manifold absolute pressure - 100kpa seems reasonable
ETC 88 is engine coolant temp ....... seems normal depending on what you have been doing and thermostat seems to be ok
[/FONT]
My guess:
[/FONT]
