- Aug 14, 2016
- Location
- leicestershire
- R230 SL500 in teal blue, R231 SL500 in black. (Vauxhall insignia diesel now sold) Black Ford Mondeo
I'd still tap and use a small set screw.....
Or screw in a 3.2mm self tapping screw?I'd still tap and use a small set screw.....
I've never had much luck with self tappers into non steel (I'm used to fibreglass),I find they split the glass too easily, but a proper tapped hole first, then a set screw always worked, just don't tighten too much.Or screw in a 3.2mm self tapping screw?
My LBS wasn’t interested. He’s very knowledgeable when it comes to the mechanical side and is an ex-racer but I don’t think he’s willing to take the risk.Frame to the local bike shop Darrell. Find a hidden gem and give them your business. I put a reasonable amount of work to my local bike shop, and they can quickly get hold of all sorts of specific bits, bolts, cogs, bearings etc. Plus they can actually find quickly the exact part I often want.
What's the sketch with the above. Are they to be removed? Are they securely enough affixed to withstand the forces of tapping?There's also the remnants of what went before still in the holes with no indication as to whether removal is required or re-utilisation.
I’ve been directed towards a carbon cycle repair place in Leatherhead which appears to be highly rated amongst the in-crowd.My LBS wasn’t interested. He’s very knowledgeable when it comes to the mechanical side and is an ex-racer but I don’t think he’s willing to take the risk.
A new place that appears to deal with high end bikes has opened nearby so I’ll call him later.
Forgive my ignorance but is that drive by wire braking and gear change? On a push bike?I could always go down the fully wireless route instead which means I won’t need the cable stops!
SRAM Red eTap AXS 2X E1 Electronic HRD Groupset | Sigma Sports
Shop the SRAM Red eTap AXS 2X E1 Electronic HRD Groupset online at Sigma Sports. Receive FREE UK delivery on all orders over £60 and easy returns!www.sigmasports.com
