Jun 7, 2006 #1 S stuart1948 Member Joined May 19, 2006 Messages 43 Can some one advise. Is Brake fluid the same as Power steering fluid? Thanks
Jun 7, 2006 #2 Parrot of Doom MB Enthusiast Joined Dec 13, 2005 Messages 1,101 Location Manchester, UK Car 1997 R-reg W210 E300TD saloon No.
Jun 8, 2006 #3 S sv4 New Member Joined Sep 23, 2005 Messages 18 Power steering fluid is the same as ATF.
Jun 8, 2006 #4 OP OP S stuart1948 Member Joined May 19, 2006 Messages 43 Thank to all who replied. Stuart
Jun 8, 2006 #5 1 1998K Active Member Joined Feb 17, 2005 Messages 894 Location Italy Car W203 C270 cdi If you need to know, normally (at least on W202) brake fluid is the same fluid/tank for clutch circuit in case of manual gearbox.
